Clutch cable ran out of adjustment? What gives?
Old 06-13-2012, 09:54 PM
06UltraBig95's Avatar
06UltraBig95
06UltraBig95 is offline
Originally Posted by cruzmisl
Here is the spacer I got from Barnett. Install was a cinch and works perfectly. Lots of adjustment room now.
Thank you very much, I will be giving them a call in the morning.
  #32
Old 06-13-2012, 10:32 PM
bagman1's Avatar
bagman1
bagman1 is offline
+1 Thanks for the info.
  #33
Old 06-14-2012, 08:36 AM
SDVmnt's Avatar
SDVmnt
SDVmnt is offline
I need the same thing. I've been "dealing" with my cable at the end of it's ajustment for over a year now. Dreading removing the f'ing exhaust. I'll be calling them as well. Thank you!
  #34
Old 06-14-2012, 08:46 AM
cruzmisl's Avatar
cruzmisl
cruzmisl is offline
It took all of five minutes to install. I dreaded removing the exhaust as well but thankfully I didn't have to do it.
  #35
Old 07-18-2012, 09:26 AM
wd8nvr's Avatar
wd8nvr
wd8nvr is offline
Stage II
Thanks guys. I've been fighting this for a couple weeks. I picked up a new (used) custom, and the clutch release bearing was froze up from sitting (2003 with only 4600 miles). After replacing it and the push rod, I had same problem with cable adjustment. Bought a new braided cable from v-twin and same issue! Adjusted many a clutches, but this one had me using various 4 letter words! Gonna go spin off a spacer on the lathe and see if it solves my problems.
  #36
Old 08-18-2012, 12:40 PM
roadstarca's Avatar
roadstarca
roadstarca is offline
6th Gear
Will this cable spacer work on the stock cables on a 2010 Ultra? I have the same adjustment issue. Thanks.
Dani Havens (03-18-2021)
  #37
Old 08-20-2012, 04:29 PM
drive2live2ride's Avatar
drive2live2ride
drive2live2ride is offline
Default perfect
This thread is a perfect example of why this forum is so awesome. I've been having this problem with these clutch cables for some time. Glad Barnett is stepping up and providing spacers. A few years back Harley started using the ez pull linkage in the baggers for sure and I don't think the cable companies compensated for the longer arm on the linkage. Internal cable should have been shorter by about 1/2" for awhile now, but no matter where I purchased aftermarket cables from was getting the same issue...running out of threads on the cable adjuster before enough slack was removed. Thanks to the OP for getting this thread going and thanks to roadstarca for posting pics of the spacer.
  #38
Old 05-21-2013, 03:20 AM
DAVENRINO's Avatar
DAVENRINO
DAVENRINO is offline
I am really glad i ran across your post! I have a new Barnett Stealth cable along with my Bandit clutch. I have a LOT of free play at the lever and no adjustment left. I bought an aftermarket EZ Pull kit, and planned to use the included spacer where it goes into the tranny. Today I called Barnett and they are sending a couple of the spacers above, so now I am saved a lot of work. THANKS!
BTW they said the spacers only work with their cables.
  #39
Old 09-24-2015, 10:45 AM
Gordon65's Avatar
Gordon65
Gordon65 is offline
for those of you with the cable spacer from Barnett, is it true that it will only work with their cable? I need one, and have the stock cable.
  #40
Old 09-24-2015, 11:19 AM
cruzmisl's Avatar
cruzmisl
cruzmisl is offline
If you have the stock cable you have other issues that need to be sorted.
Quick Reply: Clutch cable ran out of adjustment? What gives?
