Fuelmoto level b . Do you reuse headgasket?
Old 06-01-2012 | 03:14 PM
beansSG's Avatar
beansSG
Kinda hard after you crash!
Originally Posted by harleycharlie1992
I reuse them on all the airplanes I work on.......never had one come back!!!!..... I'm not sure thats a good thing!!
Old 06-01-2012 | 06:05 PM
jjnoble's Avatar
jjnoble
I would not reuse a head gasket, not ever, not even if it looked new. Too much trouble to redo everything because of a leaking gasket. I'd much rather spend a little money and not have to do it twice. If you had no other choice, which could happen, then do what you have to. But if you can run down to the store and buy one, that is what I would do. I learned many years ago if you don't like to do something, if it is hard or time consuming or costs a lot then you make extra sure you do it right the first time, because you most certainly are not going to want to do it twice.
Old 06-01-2012 | 09:23 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Shop 101; Gaskets are cheap. Buy new gaskets; Never re-use the old ones.
Old 06-01-2012 | 09:26 PM
borncountry's Avatar
borncountry
thanks for all the advice, it was all i needed to call in a new set. honestly, i didn't know what to do because I was getting advice to go in the direction of reusing. Thankful my friends at HD Shop were insiting on a new set. So , did the Cosmetic mfg company. DO not REuse!!!
Sheets1958
09-02-2011 05:54 PM
Fl Jimbo 05
08-11-2011 10:11 PM
iknowyoueazyryder
Ironhead
02-18-2008 05:25 PM
snod
Exhaust System Topics
01-28-2008 08:35 PM
jakazz
07-02-2007 10:05 AM
Quick Reply: Fuelmoto level b . Do you reuse headgasket?
