Oil Temp 257 - Normal or YIKES?
2012 Road King Classic. Rode approx. 100 miles on the interstate today. 88/90 air temp. Stock 103 with stock intake and mufflers and a catless headpipe. Factory oil cooler. Using Syn 3 and have 3k miles on bike. Cruise control the whole way at 75mph. When I stopped to take a break I checked the oil temp (HD Digital) and it was reading 257. Never been that high before. Is this normal? Seems hot to me but I know these 103's run hot.
That's normal and nothing to worry about. You may want to shorten your oil change interval though.
Syn 3 is comprised of 3 different base stocks blended together. They use a group 2 which is conventional,a group 3 which is a hydrocracked conventional and a few drops of a group 4 which is synthetic.
Because of the ratio of conventional in syn 3 it won't resist thermal breakdown as long as a real synthetic like amsoil or red line,so at temps which you are experiencing it will turn the oil into water fairly quickly.
I wouldn't go more than 4000 miles on a conventional which is basically what syn 3 is.
Now I'm not saying any harm will come to your motor nor will it blow up,I'm just throwing it out there.
I'm running Mobil 1, an oil cooler, FuelMoto 107 and a PCV with self tuning capabilities. Oh yeah, I'm also running the lower temp thermostat (thanks Jason) Under similar conditions (low 90's and 150 miles of highway riding) my oil temp just after coming off the highway was 212-214 degrees. Change to (a real) synthetic and get a tuner, your engine will thank you for it.
