Broke down in Yellowstone "Need some advice"
Old 05-29-2012, 07:53 PM
SpiderPig's Avatar
SpiderPig
SpiderPig is offline
Default UPDATE 6-2-2012 Broke down in Yellowstone "Need some advice"
On a trip with my son in Yellowstone. His 06 threw two codes. P0107 Map sensor fail and a p0374 Crank sensor. The bike started missing and we restarted it once went for a few 100 feet and died. Wouldn't restart. I pulled the crank position sensor and it looks like the surface is chewed up as the wires are showing. The bike is on a tow headed for Yellowstone HD in Belgrade MT. Any advice I would love to hear from the guys that know about what this may be. I am afraid that this may be a sizzored crank?
Old 05-29-2012, 08:11 PM
davessworks's Avatar
davessworks
davessworks is offline
Doesn't sound good at all. My guess is they're going to have to split the case to fix. No way should the crank position sensor get damaged by the crank under normal operation - so yup - it probably is a damaged crank or inside cam bearing. Your motor is probably toast. Ouch- I just don't like saying those words . . .
Old 05-29-2012, 08:24 PM
fxstc1999's Avatar
fxstc1999
fxstc1999 is offline
Sorry to hear that especially on a beautiful trip like that. Sounds like a good time to slap a 120R in if the crank scissored. Hopefully it's just a bearing failure. Good luck!
Old 05-29-2012, 08:31 PM
davessworks
Usually no such thing as just a bearing failure.
Old 05-30-2012, 07:08 AM
SpiderPig's Avatar
SpiderPig
Finally made it into Belgrade from Cody to meet up with my son who was with the bike. I will be at the dealer at 9 when they open and should know more soon. Not real happy that this is the second failure while on a trip. The 1st was when a lifter decided to seize and took out the cams,plate,oil pump etc a few years back while headed to Sturgis. I have been a H.D. guy since the early 90's. But having serious dependability questions right now!
Old 05-30-2012, 07:15 AM
stro1965's Avatar
stro1965
stro1965 is offline
There is a very good indy shop in Cody, he probably could have taken good care of you. In any case, it sucks to break down on a trip like that (I broke down a couple years ago in Sturgis on my way to Yellowstone). Good luck!
Old 05-30-2012, 07:25 AM
SpiderPig's Avatar
SpiderPig
Stro,Thanks for the information. At the time yesterday not knowing about this Indy I was focused on a dealer mainly for parts availability. The tow bill may be more than the repair! If the crank is bad, and the cases need to be split, does anyone know the time frame to do this job?
Old 05-30-2012, 07:40 AM
t059736's Avatar
t059736
t059736 is offline
Stro1965-
Will you provide all of us with the information on the really good Indy shop in Cody?
It always nice to add this information into the travelling guide.
Thanks
Ride In Peace
Old 05-30-2012, 09:38 AM
rmc115's Avatar
rmc115
rmc115 is offline
06's seem to be the worst for destroying the inner cam bearing and sending shrapnel through the engine. I repaired a friends 06 street glide with the exact same issue,complete engine rebuild and case repair. Sorry about your trip. Mike
Old 05-30-2012, 09:45 AM
SpiderPig's Avatar
SpiderPig
They are tearing into it right now. They found that the rear cylinder has 60 psi and metal that was attached to the crank sensor was aluminum. Once the top end is off I will know more in a couple of hours. Preliminary thought is that the rear piston failed and may have took out the head and cylinder with it. The problem is that these HTCC parts are disc from H.D. and might have an issue finding them.
Quick Reply: Broke down in Yellowstone "Need some advice"
