1000 Mile service, should hd do it?
2010 sg due for the first service. I dont have any factory warranty left as I'm the second owner and due to age of the bike. Hd wants over $450 to do the first service and a local chopper shop that works on HD will do it for $325. Does it matter who does it? Is a HD mechanic better or more qualified then a mom and pop shop mechanic? The place is called Big Daddy Cycles in Hayes, Va. Never heard bad things or good about them? They told me they will do the same work as the HD dealer and inspect/adjust everything.
Thoughts?
Thoughts?
The dealership has a checklist they use when doing the service (of which you should be given a copy). Some indy's don't have that. Whether or not they hit everything they're supposed to isn't the issue. It's proving to the dealership that it was done correctly if there comes a time for warranty work.
If the indy doesn't use a checklist, then I'd be worried because it's a pretty important service. Things work loose, and the dealership knows what to look for.
On the other hand, not all dealerships are thorough either. One way I check is to ask them how long it will take to do it. If either gives me a short time estimate, I would go elsewhere. I've had my 1,000 and 5,000 mile service done at the dealership. Both took over three hours from the time it went up on the lift. I had a indy do the 10k to save a hundred bucks. It was done in 45 minutes. I still worry about that one, and won't be going back. I know for a fact they didn't check spokes, or critical fasteners.
The hd dealer will have access to the latest recalls, like the brake switch if not already done. He will have the upgrades to the stereo, all things the indy wont have. Since thebike has so few miles, let the dealer go overit. They have a checklist that they go by. My money would be send to thedealer. If you want to develop a relationship with the indy, do so gradually.
Save yourself the money. I am as handy as a one handed baboon and I was able to change all three fluids. Cost.... $75.00. Each spring, I do send the bike to a mechanic to do a quick check to see if anything needs tightening, adjusting or lubing. He charges me $90.00 to go through the bike. As long as you change the fluids religiously, you shouldn't have any issues on a new bike during the 2 year warranty period. Just my opinion.
I think the 1k is important enough you might want to have the dealer do it.
