FLHTCI Noise in front end
05-26-2012, 08:37 AM
I just started hearing a noise in front end, only when going through curves; bends if you will. It is a Humming sound
05-26-2012, 08:42 AM
05-26-2012, 08:51 AM
sounds like the front tire has cuping and probably low pressure
05-26-2012, 09:14 AM
05-26-2012, 09:16 AM
cupping,the front tire is most likely to get it,u can see or feel the uneven wear,likely cause is low air pressure or ALOT of hard front braking.
05-26-2012, 09:25 AM
And perhapes this would account for the looseness in front tire when hitting small pot holes
05-26-2012, 09:27 AM
perhapes this would account for looseness in front tire when hitting small pot holes
05-26-2012, 09:34 AM
loosness in front wheel ? didn't see that in first post.that would be likely be wheel bearings.running on bad wheel bearings could also cause cupping.wheel bearings can be dangerous.
05-26-2012, 09:36 AM
Is there an easy way to check bad bearings in front
05-26-2012, 09:41 AM
YO Brother, is there an easy test to check for bad bearins
c50plus
07-31-2014 03:42 PM
mikkeeh
06-10-2013 07:37 PM
Free Spirit
05-29-2011 11:59 PM
PiedPiper
09-04-2008 06:56 AM
bundy bruiser
04-04-2008 07:18 AM
