Clutch hard to pull in
Plus make sure after you adjust clutch pack you pull lever thre or more times to set the ramp.
Try it this way. Someone posted this method on the forum and you get spot on results every time.
Completely collapse the clutch cable. Gently hold clutch with your finger against the the grip while adjusting the clutch pack. As soon as you feel the slightest resistance on the clutch lever, find that sweet spot and then tighten the jam nut. Set the clutch cable until you have about 1/8" play. Squeeze clutch several times to set ramp.
If this does not work then consider plan B.
I found my original cable stretched to the point I ran out of adjustment screw threads before I got the 1/8" freeplay...that was really annoying. Having to do again, I would adjust it at first service then dont touch it till 5 k or more. The replacement cable I got for my apes shows stock pull at 3 1/2" but wondered if a shorter pull would allow more adjustment room at 2 3/4" or even 2 1/2". That extra inch at the adjustment thread would be welcome. I thought about starting a thread on the subject for discussion but its hit or miss on how long the thread stays visible and how long Im willing to wait till I get viable intel. Havent figured out if title wording is critical or what it takes to get good participation. I started a thread once with ' who uses their rear brakes exclusively?' just to experiment to see what the participation level would be and was astounded that 17 + pages later it was still going. Then a badly needed info thread some time
ago and barely got any participation. Interesting to say the least.
cnielsen4130
10-15-2006 10:28 PM
