I have seen where the tour pak organizer has been installed using the tour pak bolts and fender washers to hold it in place. Anyone done this who has the Air Wing Rack with the LED LIght? It has the hollow bolt that the wires go thru?
Yes, I have done both. What I did was have all 3 standard bolts go through the organizer and then the one with the wires just stayed behind the organizer. I believe I had to get a longer bolt for the other lower mount based on where it all setup with the curves of the tour pak top.
