Rear engine mount information
Old 01-07-2007 | 02:57 AM
magna3500hd's Avatar
magna3500hd
Default Rear engine mount information
I've read a lot of threads on here about the vibration from a badfront engine mount and I believe that's what I'm feeling on my 06 Ultra. I can feel a vibration in the footboards and the seat all through the RPM range that I didn't have a month ago. Should I go with another OEM part, or is there an aftermarket mount superior to the HD mount and who sells it? Also, could anyone tell me how the rear of the engine is mounted to the frame? Does the rear have rubber mounts that go bad? If so, how do you check or replace them? Thanks
Old 01-07-2007 | 03:05 AM
Bryan TTM's Avatar
Bryan TTM
Default RE: Rear engine mount information
the tranny and engine are linked together...the missing link is on the rear...true track or ridestr8 correct that...without them the rear is a boss on the back of the tranny that the swingarm pivot bolt(long and thick) goes thru...problem is, its rubber and will deflect
Old 01-07-2007 | 09:21 AM
dog155's Avatar
dog155
According to HD the front mount is good for 10,000 miles,The rear must be the same.There is really no way to check other than visual.After market offers front motor mt limiters,poly mounts,for the rear all you have are limiters as well,Sta-Bo for example.Your vibration could be something other than rubbermounts.
paulvs
11-08-2017 07:54 PM
newdyna
01-20-2016 11:22 AM
Deathbat9
06-09-2015 11:59 AM
sgt. slaughter
10-25-2012 06:07 AM
500MAG
Exhaust System Topics
05-15-2007 08:34 PM
Quick Reply: Rear engine mount information
