Input wanted on pulling a trailer
With the exception of the tongue weight, I can't add much more to what has already been said. However when it comes to the tongue weight the figures mentioned above are only guidelines.
With all of that said, my camper weighs 255 lbs empty. With the options and cargo I carry its' gross weight is approximately 375 lbs. I use a Walley World fish scale to keep my tongue weight between 40 to 45 lbs. and I have no problem with the trailer tracking straight and true at interstate speeds.
- The specified maximum tongues weight on most motorcycle hitches is 50 to 60lbs.
- 10% of your trailer weight rule will put many trailers with cargo in the 20 to 25 lb tongue weight range
- however loading your trailer so that the tongue weight is too light will cause your trailer to 'wag the tail' and trust me, you do not want that to happen when you reach cruising speed
look at harbor freight i have the same trailer never had a problem run smooth at 70 mph
http://www.harborfreight.com/600-lb-...ler-66771.html
I assume you used it with your motorcycle ..
I have pulled a trailer for over 100,000 miles? everything from a flat beds, cargo to pop up camping trailers - I was on a Goldwing everyone of those miles - Bought my 1st cargo trailer in 1983 - A goldwing pulls 118 HP stock - lot of difference between that and the HP a HD pulls - I'm finally starting to enjoy my Ultra but it does work me to death in the mountains because of the air cooled engine & low HP- I know a lot of guys pull trailers with their harleys but I just wouldn't do it myself - If i was going to pull a trailer I would want a water pumper for an engine and a lot more HP than I now have! Thats just me - your results may differ
Also - Here in CA the speed limit pulling a trailer is 55 MPH! doesn't matter if you a motorcycle or an 18 wheeler. 55 MPH
JimGnitecki
General Topics/Tech Tips
82
01-04-2018 10:58 PM
