Stereo cuts out. Help me figure this out.
I've upgraded my sound system. Put in a 500w 4 channel JM amp. 4 Polk audio marine speakers. A pair of 6.5" in the dash and a pair of 6x9's in the saddle bag lids.
After hooking everything up according to the manufactruers specs, and using their cables the system sounded great. But, after cranking the volume to a bit over half the system would shut down after about 5 or 10 minutes.
I described the problem to JM and they replaced the Amp. Today I reinstalled the new one checked everything. After about 20 minutes on the road it cut out. Same problem.
While I had it open I put an ohm meter on each pair of speaker wire pairs and measured exactly 2.7 ohms per channel. I don't think there is anything wrong with the wiring or speakers. They sound great when they're playing.
So here's what I'm thinking.
- Maybe the head unit is screwed. Although it has always worked perfectly before I added the amp.
- Maybe the Amp isn't compatible with 2.7 ohm speakers.
- Maybe the remote wire is cutting power to the amp. Is that even possible?
I can't see the Amp, it's under the fairing. When I got home tonight it was still cut out, i was going to quickly pull the fairing and trouble shoot it, but just as I put the bike on the side stand the music cut in again.
What's going on? Give me some ideas.
Try this. If when the sound goes off hit the speaker switch on the fairing, toggle up or down, or turn off then back on. If this is it it will stay on few min maybe several then off again toggle again. If so head unit. Had same problem after installing amp. Had to pull and send to iron cross, did excellent job couple of months no problem. Also had aux port put in back of unit. Hope it works out.
I had this exact problem. Was about to return my amp for a new one. Look at where your ground is for your amp and make sure you scrape any paint where the ground hits the frame. Even as I was scraping on my bike, I thought, this is going to help. Bingo, that was the trick. Not another problem since.
Had the exact problem. Ended up on last Sturgis trip with NO radio.. Trying the speaker selector switch will help, but didn't last. Ended up being a head unit. Replaced twice!
I still have issues I think with that big plug of wires behind the radio, try wiggling it up or down and see if it comes back on. Good luck!
+1 on checking ground. Also check the amp and make sure it's not overheating for some strange reason
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
General Inquiries:
Phone:
775.331.3789
