Installed Phase 7 LED headlamp and passing lamps
Picked up a set of Truck Lite Phase 7 Headlight and passing lamps.
Install was quick and easy as others have said. I did have to buy the french trim rings. The passing lamps fit fine but the headlight stuck out like a sore thumb.
All I gotta say is WOW. Holy moly they are bright. I ride a lot in rural unlit areas. My only gripe is that when I come up on those super reflective, slime-lime, safety green color street signs and the high beam is on, it almost sends to much light back. A small price to pay I suppose. I did have a complaint from a rider in front of me that said they were too bright. In my defense, I do believe that the headlight is aimed a tad right as indicated by the hotspot. Also given the brightness of the main lamp I turned my passing lamps outward so as to better light up critters. A second test later with the passing lamps off yielded better results. With that said, at no time did I have any opposing traffic flash me. Perhaps that is because the headlight may be slightly aimed left or that it is just a well controlled light pattern.
Either way I am done with halogen lighting on the bike.
Also during that test I was able to observe a newly installed BAL-1. Good grief. I never knew how bright they were. I mean I've messed around in the garage with mine but a few hundred feet down the road and its crazy bright. To anyone who is on the fence about buying one, I highly recommend it.
