Installed Phase 7 LED headlamp and passing lamps
Old 08-14-2012, 07:28 AM
ratdoc's Avatar
ratdoc
ratdoc is offline
Originally Posted by LDB415
Thanks for the info on the two. How do those compare for day and night lighting to the HD LED headlight?
http://bogiesreviews.webs.com/Review...ng%20Lamps.pdf
  #62
Old 08-14-2012, 07:35 AM
BigGdawg's Avatar
BigGdawg
BigGdawg is offline
Phase 7 Truck Lite Headlight and Passing Lights - I put my set on a couple weeks ago and really have seen the difference over the stock lights on my 2012 UL. Bought mine at discountfleetsupply.com and got them the next day.
  #63
Old 08-14-2012, 10:43 AM
Bugsy's Avatar
Bugsy
Bugsy is offline
How about the Phase 7 Headlamp paired with Phase 6 spot lamps? The spots would take care of daytime visibility and the Phase 7 for better lighting at night.
  #64
Old 08-14-2012, 10:48 AM
Bugsy's Avatar
Bugsy
Bugsy is offline
How long do those 894s last for you? GE gives them a 200 hour life rating. Not a lot if you want to leave them on all the time.
Originally Posted by troop
I'm currently using a pure yellow 894 bulb (37.5w), versus stock 881 27w bulb. Can't remember what brand I'm using but the Nokya 881 hyper yellow bulb would also work well. Below is info from another post:
If you have a standard 881 bulb in your 08 Ultra , there are a few different bulbs you can go with.
The 881 is a PGJ13 right angle bulb , so here are a few alternatives
881 27.5 watt
886 50 watt
889 27 watt
894 37.5 watt
896 37.5 watt
898 37.5 watt
A couple have clear tips but the standard is usually black tipped.
All are PGJ13 and will pop right in the housings.
I have safely run 37.5 watt in mine and had no problems , 50 watt might be a little high for the stock wiring.
Aim is critical ( and a real pain) for the best results.
I personally run amber passing beams with the thought that oncoming traffic "sees" me better.
  #65
Old 08-14-2012, 11:21 AM
LDB415's Avatar
LDB415
LDB415 is offline
So that would be maybe 7-9k miles then on average?
  #66
Old 08-14-2012, 11:33 AM
troop's Avatar
troop
troop is offline
Hrs wise I don't know but have 7k miles on them. Not a big expense and easy to replace so not a big deal to me. I did find a local Nokya dealer who'll sell me some 881 hyper yellows for $17 so I'll probably try those when the time comes to replace ....
  #67
Old 08-14-2012, 11:42 AM
lgenf's Avatar
lgenf
lgenf is offline
Originally Posted by sixty4nhalf
This was my first add on to the `12 EG U/L, I got all 3 lights as well for $433. Next I want to get the BAL for the rear, any places you know of have a great deal going on??
chiming back in, as I have a discount hook up on this also
call Kevin from Hampton Roads Harley-Davidson
6450 George Washington Memorial Highway
Yorktown, VA
(757) 872-7223
I think it was a 20% off discount for the BAL products when I ordered.
  #68
Old 08-15-2012, 08:22 AM
sixty4nhalf's Avatar
sixty4nhalf
sixty4nhalf is offline
Originally Posted by ratdoc
I'm really trying to decide about these lights. Do you have any thoughts on the daytime visibility of the Phase 7s?
This is a very worth wild addition to the bike, you have no problems being seen either day or night!
  #69
Old 08-15-2012, 08:30 AM
ratdoc's Avatar
ratdoc
ratdoc is offline
Thanks for the input. I decided to go for it and they're being delivered today. Can't wait to get them on.
  #70
Old 08-19-2012, 08:32 PM
Bushy's Avatar
Bushy
Bushy is offline
Eastern performance, 225 to your door
Quick Reply: Installed Phase 7 LED headlamp and passing lamps
