Installed Phase 7 LED headlamp and passing lamps
[quote=HDSledge;10027192]The visor style works, I have one.
Question: Only have one location left with regular bulbs in the front turn signals. Kuryakyn Panacea on back. Does anyone know if I will need an additional load equalizer to convert the front turn signals to led?
No you only require the equalizer on the rear turn signals.
I also use the visor as mentioned and it works just fine.
You don't have to remove the fairing. Turn your handle bars all the way to the left and look up under your accessory and cruise control power switches. You will see a connector. Using one or two fingers work that connector down and out from underneath. Once you have it clear unconnect it and install the new connection matching up the male/female connectors. Once you have the connections made push the connectoion blocks and wire nest back up under the switch cover housing and you're done.
[quote=Nute;10186649]
Thanks Nute! Guess I'll go with the panacea ones since I have them in the tail lights.
for those of you wanting to save a few bucks over Kury pricng on this set up
Discount Fleet Supply has them cheaper
Headlight
http://www.discountfleetsupply.com/tlc27270c.html
running lights
http://www.discountfleetsupply.com/tlc80275.html
PLUS if you use the discount code HDLED5
you will get Free Shipping and an additional 5% off!
Headlight
running lights
I'd like to install the phase 7 LED headlamp on my FLHTK. But I am still confused with the headlight ring -- I have the headlamp visor (67752-77T) on my stock headlamp. If I install the Phase 7, and need the french ring, will that visor fit with the french ring?? Thanks for any advice.
According to that this part won't go on with the trim rings..
