Installed Phase 7 LED headlamp and passing lamps
im guessing that if it is only like a visor bolted or snapped to the top of a normal ring then no. It has to do with the depth of the entire ring. They do make a frenched ring with a built in visor
http://www.harley-davidson.com/gma/g...5&default=none
but if you have this:
http://www.harley-davidson.com/gma/g...3&default=none
then I suspect you will have the same issue with the stock ring
Straight from Kuryakyn
http://www.kuryakyn.com/Products/420...-Passing-Lamps
Minus the goofy LED trim ring.
The rings I got from a local stealer
Kuryakyn LED Headlights!!!!!!!
Getting a bit older now and driving in the Black Hills after dark had gotten really DARK.
looked at LED headlight and running lights and HD were nearly $1000....Unbelievable!
I had gotten Kuryakyn Panancea tail-lights installed at the rally last year so looked at their products and picked their new LED headlight and runners from Henley Kustom for less than half the HD price and the difference is like.....Well, like night and day.
For safety and security and becasue the Halo ring looks really cool get the Kuryakyn product. It's all 'plug and play'..... so easy a senior citizen can do it.
Absolutely the best safety and style purchase you can make. throws light twice the distance of standard lights. Go. Buy them Now!!!!!
Visor style trim ring fits...
I opted for the Phase 6 since I like the non traditional look of them and they are a couple hundred cheaper. Got all 3 for 375 shipped from Eastern. Also got the led trilite bulbs from Custom Dynamics to put in my Motolights. Blows away the halogen ones.
Going to see how far down I can point the spots since they are super bright in rear view of cages ahead of me. No comments but noticed at least one driver reaching for the rearview mirror to move it. They look too bright imho and the beam is not focused very well. Don't have very much vertical adjustment capability on the spots on my ultra looks like I might get a few degrees tops. UPDATE: I was able to muscle them down at least 15 degrees which was plenty. The trick was to turn back and forth while pulling forward. Didn't have to take off the turn signals or hacksaw a 9/16 to adjust them. Problem solved with brightness, they were just pointed way too high for this light. You'll definitely have to realign all of them after the upgrade.
Also got the harness (69200442) from hd to allow high beam and spots same time.
In case anyone hasn't seen the reviews, I attached a couple pics. I'll be led lit from now on. It's a huge improvement. If you look directly into these you'll see spots for a few minutes. No way someone in front can miss these so surely the chance of the proverbial cager left turn in front will go way down.
Question: Only have one location left with regular bulbs in the front turn signals. Kuryakyn Panacea on back. Does anyone know if I will need an additional load equalizer to convert the front turn signals to led?
Thanks
Sledge
Independent Control Auxilliary Lamp Wire Harness Kit
Here's a link to the install guide:
http://www.harley-davidson.com/en_US...ts/-J05535.pdf
$29.95
Haven't put mine on yet. Let know how it goes.
Update:
http://www.harley-davidson.com/en_US...ts/-J05534.pdf is what I need, the dealer sold me the wrong part. I need 69200441 for the FLHT.
for those of you wanting to save a few bucks over Kury pricng on this set up
Discount Fleet Supply has them cheaper
Headlight
http://www.discountfleetsupply.com/tlc27270c.html
running lights
http://www.discountfleetsupply.com/tlc80275.html
PLUS if you use the discount code HDLED5
you will get Free Shipping and an additional 5% off!
Headlight
running lights
and
http://www.harley-davidson.com/gma/g...bmLocale=en_US
On mine in above pics. Fit very well, actually better than with the stock lighting. Kuryakyn has a nice one with leds all around it if you are into that sort of bling.
$40.95 69740-01 Frenched Style Turn Signal Trim Rings, Chrome (2)
$54.95 69622-99B Frenched Style Passing Lamp Trim Rings, Chrome (2)
$37.95 69627-99 Frenched Style Headlamp Trim Ring, Chrome
Last edited by HDSledge; 08-10-2012 at 12:15 PM. Reason: added part numbers for Frenched rings
