Rear Brake - after switch replaced.
Old 05-20-2012, 05:33 PM
IzZy63's Avatar
IzZy63
IzZy63 is offline
Veteran: Marine Corp
same story with me,took it back to dealer the next day and it's OK nnow.
Old 05-20-2012, 06:26 PM
Inspector 12's Avatar
Inspector 12
Inspector 12 is offline
After watching threads like this and talking with a couple of shops that are doing the work I am determined to not fix a problem that doesn't yet exist. Since I got rid of the head pipe with the cat in it I figure the heat source that was killing the recalled part is gone.
Old 05-21-2012, 02:49 AM
Expat1's Avatar
Expat1
Expat1 is offline
Location: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Originally Posted by journeyman
This is the reason I never took mine in for that warranty.
I really don't trust those guys at all.
Our magnificent HD dealership refuses to sell the replacement brake switch as a spare part...
I'm glad I seldom use the rear brake while in cruise control
Old 05-21-2012, 06:07 AM
Rickr01's Avatar
Rickr01
Rickr01 is offline
I purchased the switch and replaced it myself. Bled the brakes and all is just fine. Purchase a set of speed Bleeders and install them at the same time you change the switch. Makes it a snap to bleed and change brake fluid. Yes mine is ABS also.
Old 05-21-2012, 06:33 AM
Expat1's Avatar
Expat1
Expat1 is offline
Originally Posted by Rickr01
I purchased the switch and replaced it myself. Bled the brakes and all is just fine. Purchase a set of speed Bleeders and install them at the same time you chenge the switch. Makes it a snap to bleed and change brake fluid. Yes mine is ABS also.
I read somewhere we had to remove o-rings left under the original bleeders; do you confirm? I also bought the SB8125L-SS bleeders ...
Old 05-21-2012, 07:57 AM
FenderGuy53's Avatar
FenderGuy53
FenderGuy53 is offline
I had my brake switch recall done a few days after my 1000-mile service (they were supposed to do both at the same time). I haven't noticed any ill effects.
Old 05-21-2012, 09:15 AM
hoethree's Avatar
hoethree
hoethree is offline
Looks like SB8125L is the right one for my 2010 StreetGlide. Anyone know the correct one for a 2009 Softail Deluxe....not clear on the chart. thanks
Old 05-21-2012, 11:04 AM
Expat1's Avatar
Expat1
Expat1 is offline
This is for BREMBO brakes (dia 8mm / pitch 1.25mm)
Old 05-21-2012, 08:45 PM
glenalt's Avatar
glenalt
glenalt is offline
Had mine done a few weeks ago and no problems.
Y'all need to have it done. There is no warning when it goes out and you have no rear brake. Yikes!
Old 05-21-2012, 09:01 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
Rick...did you see any air bubbles come out during the bleed?
Quick Reply: Rear Brake - after switch replaced.
