Saddle bag latches
Saddle bag latches
My saddle bag latches don't stay latched or down they pop out and once the lid actually opened up after a road heave. I started locking them but that is a pain.
I know other people don't seem to have this problem or if any thing once in a while the latch pops out but that is it.
Is there a way to adjust them or do I have to keep locking them.
Received 75,083 Likes
More than likely the little spring on the hinge is broken. It is only about an inch and half long and under the cloth flap. Do a search on here and you will find a shitload of help in replacing the springs. They are less than $2 a piece at MoCo and with the help on here can be changed out in less than 30 minutes. Good luck.
Make sure you are closing them properly. If the tabs on the lids are not pushed under the catches on the bags all the way, when you close the hinge it will feel mushy and close with a dull thud sound, if you get any sound at all. If you do it properly the hinge will snap shut with a clean slapping sound. Hard to explain. Intentionally do it wrong and listen to it and feel it, then make sure you do it right and check out the difference. If not shut properly, they will pop open.
I know what you guys are talking about with the fabric being in the way and not having the lid in the back holders properly. I can tell when I get it correct because they snap shut.
Was thinking of having to bend the tabs but was hoping some thing more mechanical. I will check the springs.
What is this search you speak of, I'll be a man and tear it apart, take twice as long probably brake some thing then come and do a search and find the easy and correct way.
