Power Vision Ordered!!!!
I suppose if you have one bike to your name and it's one with the center-mounted ignition switch you could forego the kill switch. I don't, I have four and the ignition switches are in very inconvenient locations on two of them. So I use the kill switch on all of them, old habit.
I've owned numerous bikes with ignition switches mounted in every conceivable location and still never wanted to mess with that abominable switch. It's an open invitation to leaving the ignition on and lights running, depleting the battery, as well as odd issues like you had with your PV.
Well I put a couple more rides on mine today and I can tell a difference in performance now that I've gotten to wring it out some more. It's not a night-and-say difference, but it definitely pulls harder throughout. When I rode it earlier it was super-windy which was probably masking the performance improvement.
That's total crap. I've logged 42 years of riding and using kill switches and have had zero problems. The deal with the PV was not an "odd issue", it was a simple matter of getting an error message and flipping the switch and trying again. They should have mentioned it in the instructions but they didn't, that's why I mentioned it, so that others could take note of it.
I now have the PV and kept the AT-100 kit with WB sensors, but it does not "auto-tune" by the above definition. What it will do is tune the entire operating range as an open-loop device, what DynoJet calls "Pro Tuning." IOW, you log 11 parameters from the ECM and two from the WB sensors (front and rear cyl.), then let the PV Tune software juggle the numbers and create a new tune, with a few other steps in between. This works well too and although the WB sensors can't interact with the ECM it can tune in this fashion as well as allow you to monitor AFR's while riding. The PV has a cool display unit that can show numerous ECM and other parameters in real time.
Warning: I'm getting off on another tangent here, but...
If you want to use the AT module and run in closed-loop you'd need to replace the WB sensors with the stock NB units after tweaking your tune, or better yet weld another set of 18mm bungs on your pipes and run two O2 sensors for each cylinder. Then you could tune in open-loop mode and after that's done change to closed-loop without removing or reinstalling any hardware.
If you don't have the AT-100 kit and use the stock O2 sensors you can tune in limited closed-loop, called "Basic Tuning," mostly just at idle and the cruise range. This is the way most people tune with the PV.
There's also speculation that in the future there may be a true AT kit available that will allow closed-loop operation with the WB O2 sensors. Stay tuned.
The silly and duplicative "Run/Off" switch only serves to add unnecessary complications to operating our motorcycles. There's no way to put a happy face on it. Just leave the damned thing in the "Run" position and forget about it. Problems solved.
Until then, I'll just resign myself to accept the current limitations of the PV, and wish for more.
