FLHX Rear Lights Schematic?
Ok guys, like most I’m not happy and concerned about the lack of lighting on the rear of my 2012 Street Glide.
Today I received my LED conversions from Radiantz and I also purchased two Intagratorz (LED strip that alternates amber and red).
I would like to hook the red LEDs on the strip up to my brake lights and integrate a "Back Off" to them. For the Ambers I would like to hook up just for the turn signals.
Could anyone provide me with a schematic or color of wires that I need to tap for just brake and just turn signals?
Thanks,
J
Thanks,
J
Shop manual is the best $60 you'll ever spend. If you have a voltage tester, yu can press one end into the wire and turn on the brake lite or turn signal you are trying to find. Or, if you open up the brake light, or turn signal, you will be able to see what color the wire is. Mine is a 99, so likely they are not the same.
The wiring diagrams are here: (http://harleytechtalk.org/htt/index....msg168334.html). You will need an account. It's free.
I have a brightasslight on mine 09 FLHX. It has alternating flash patterns for brake light activation and 3 brightness settings. Check it out at www.brightasslights.com
Also, trying to keep the clean look on the back so I dont want to add a BAL.
Thanks,
J
Location: Western Illinois, land of bad roads, and corrupt politicians
If you want to isolate the turn signals so you can run amber, I think you will have to tap in BEFORE the Facia/Converter Module. That should reside under the seat someplace ..........................
If and when you do this...... be sure to document everything and take pictures. You would be a hero to some people here.
#1 v/bn= + brake turn right
#2 v = + brake turn left
#5 BK = - brake turn left
#6 BK = - brake turn right
#7 BK = + license plate light
#8 BE = + run left
#9 BE = + run right
#11 BK = - license plate light
#8 BE = + run left
#9 BE = + run right
#8 BE = + run left
#9 BE = + run right
#8 BE = + run left
#9 BE = + run right
SmittyFXDL
01-11-2013 07:07 AM
perryross
12-14-2011 07:28 AM
BrianABE
09-23-2010 08:52 AM
