Street Glide turn signal/running lights?
RE: Street Glide turn signal/running lights?
ORIGINAL: soos
Yes, HD # 69462-06, page 380 in the 07 accessories catalogue. I am not sure what your bike model is but these may fit.
Ditto that on the part number. I just bought this at my dealer a few days ago and put them on my SG. It cam with red lenses and the plug in module. Pop on the lenses and plug the module in under the seat. What a difference. The red glow of the running lights really glows at night.
My dealer also had the older version on clearance that only lit up when brakes were applied....no running light function. It was marked down to 39.95 where as the current model is like 54.00 ..
I couldnt decide on old version with clear lenses and red bulbs (seen that on a blue SG while there)...or the new version with red lenses. Then there was the thought about smoke lenses etc.... Too many choices.
I went with the new one and red lenses for now so all lighting in rear is red. Now I just need to get the chrome bezel deuce style lenses. Been nice to get bezels with the kit, but that would be too easy and cheaper.! lol
I installed the "standard" touring Run-Turn-Brake kit on my E-Glide (P/N 69461-06) within a day or two of my dealer receiving their first shipment of them last summer. This is the one that includes two red "flat" lenses, you'll probably need the other kit (for the differentlenses) for your Street Glide. It is a super-simple installation: remove the seat, unplug the electrical connector under it for the tail light wiring, plug each side of the harness into the new module, then replace the amber rear turn signal lens with the red lens. It is a tremendous improvement in visibility of the bike, operates the stock single filament bulbs on a lower voltage for running lights at all times, brings them up to full brightness for brake lights and for flashing as turn signals. I highly recommend it.
ORIGINAL: BadX
Your correct the Part number is 69462-06 I searched through all my post and found my original post on it. I think these are actually for a dyna glide or something, works great and I love the extra lighting on the rear.
ORIGINAL: soos
I have the old version that just converts to brake lights with no running application.
ORIGINAL: soos
To the best of my knoweledge, the plug-in unit itself is the same for all models from the sporty to the touring bikes. The difference is the lens. Why you have to go looking for the bullet style lens kit in the dyna section for a touring model bike is ridiculous. They should have both kits listed in the touring section. Not all tourers have the pancake lenses.
ORIGINAL: BadX
ORIGINAL: soos
Relax, I didn't mean you personally when I said "Why you have to go looking for the bullet style lens kit in the dyna section for a touring model bike is ridiculous." I meant why should anyone have to look inthe dyna section for a part that goes to a touring bike, it should be in the section that cover their bike.
ORIGINAL: BadX
If I remember correctly you have to special order the kit for the SG's and they are actually for another HD. I'll try to see if I can find the part number. I posted it a while back when I did mine.
