Oil Change Guru's
Mkguitar.
I guess you believe the oil companies hype then.
Any 20w-50 will work fine in my twin cam 106. Those v-twin oils,you know the ones,are more geared to the shared sump bikes,not bikes with separate primary,engine and transmission fluids.
The v-twin oils contain little to no friction modifiers,which help the clutch but not necessarily the engine. Automotive oils have very high in friction modifier levels and cars are easily turning 200000 miles now,with those types of oils. Yet a Harley seems to die young in comparison.
And what mix exactly are you referring to. I have a scavenger which drains pretty much every drop of old oil out and fill it with a single brand and type,so I must admit some confusion to you post.
There are riders in this forum who have been using auto castrol 20w-50 and have 100000 miles on their bikes so I fail to see a connection.
You guys use whatever you like in your engines,I really couldn't care less. I will use whatever I like too. K
While we live in an age when information is everything, I don't think one of those devices is going to prove useful. The recommended intervals for changing oil are probably aimed at mixed running. My trip will be long days of steady mileage, so oil and filter should be fine. I suspect the dirty stuff I drain when I get home will still feel very oily!
Most all new General Motors vehicles have a "oil life" display. Most of them will let you get a crap pot load of miles, well past the 3 to 5000 mark on hwy driving. BUT, on the pre 2012 3.6 liter motors in the Lambada platform (Chevrolet Trailblazer, GMC Acadia ect). That monitor was very very wrong due to the use of natural oils and them breaking down much quicker. They had quite a few engine rebuilds due to timing chain issues. They found out using synth or a mixture of synth oil was the answer and they changed their oil requirements etc.
Now the oil life monitor works as advertised as long as you use the oil they specify.
MFG's make products to make money, no matter if it's oil, engines etc. Oil companies have a totally different take on it than the vehicle manuf. Go figure.
I am always looking for tools to make my life easier, and my vehicles last longer.
What is the scavenger oil changer that you mentioned. Sounds like that might be a good thing to use.
Glenn
Glenn
Snake oil, you don't need one. Think fishing tackle gizmos, bikes will do over 100000 miles without one,but it's your choice if you want to be caught "hook line and sinker"
