Oil pan "Hex Plug"
Old 02-19-2017 | 05:52 PM
ORradtech's Avatar
ORradtech
Originally Posted by TheGrandPoohBah
Oh no, you mean you messed with the "Thou shalt NOT mess with the hex plug?
Maybe it will leak, maybe it won't, however your pecker will rot and fall off in three days.
My condolences go out to you.
Let's hope it doesn't leak! The OP put it in with red loctite. That stuff is tough to get out!
Any tapered IP fitting you want to use thread sealant on, not any type of loctite - unless they are making thread sealant now too.
Old 02-19-2017 | 06:58 PM
ricktherocket's Avatar
ricktherocket
removed mine and installed the sending unit for my oil temp gauge and couple years ago and it has never leaked, I'll be doing the same to my new +1.5qt oil pan when I install it on the bike in the next week or so.
Old 02-20-2017 | 09:22 AM
nutsandbolts5212's Avatar
nutsandbolts5212
Originally Posted by bklynbob
No o ring,pipe sealant........
Thanks for the correction, my brain fart!
Old 02-20-2017 | 09:52 AM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
Double post
Old 02-20-2017 | 10:16 AM
ROCKOUT Rocker Products
Sponsor
This guy removed that plug...
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
tjconnection (04-05-2019)
Old 02-20-2017 | 10:34 AM
hattitude's Avatar
hattitude
I have always used something to seal the threads on tapered fittings, especially on my air lines/tools. I have used teflon tape (both white & yellow), rector seal 5, rector seal Tplus2, and permatex thread sealant.... the rector seal products have been my favorite, but I find them a little messy to use.
I saw a recommendation on Loctite Thread Sealant 545. It is easy to use and so far has worked as good as the rector seal products. It is my new favorite...
FWIW...
Old 02-20-2017 | 11:07 AM
Sponsor
FWIW the '15 touring factory manual says 18-22 ft. lbs, Loctite 565.
Old 02-20-2017 | 11:09 AM
From_Behind's Avatar
From_Behind
Old 02-20-2017 | 03:53 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by Lyle Newcomer
I have a 2011 streetglide. I accidentally removed the hex plug on my oil pan. I had some oil come out. Will I have any issues with my mistake?
Were you on Pain Meds too? I think this happens every 4 years and 9 months
Old 04-05-2019 | 09:32 PM
JR.62's Avatar
JR.62
Stage II
Default OIL Temperature Gauge
I remove the hex plug and install an oil temperature gauge for less then $30.00. No oil leak and i get a real time reading of my oil temperature going back in to the engine.
Quick Reply: Oil pan "Hex Plug"
