bottom leg thread snapping clean off
Old 05-12-2012, 05:41 PM
chopper king matt's Avatar
chopper king matt
chopper king matt is offline
Default bottom leg thread snapping clean off
I have a 2006 RKC and after a good days ride got home to clean her and noticed the left fork leg at the bottom where the spindle goes through and two bolts hold it on had sheared completely off to the extent that the wheel was wobbling in the legs
there are two 13mm or 1/2inch bolts at the bottom what hold a clamp on the foks and the wheel spindle in place and one had totally gone and i was wondering if they are a part of the leg or can they be taken out and a new one fitted ?
other than that im thinking that a specialist machine engineer can cut the thread part off and drill and tap the bottom of the leg so that a bolt can be fitted instead ?
thanks in advance
Matt
Old 05-12-2012, 05:46 PM
DTTJGlide's Avatar
DTTJGlide
DTTJGlide is offline
The lower legs are already tapped, hopefully you can get it to come out using a visegrip or something similar. You can use a bolt if need be, but it's better to replace with a stud.
Old 05-12-2012, 05:52 PM
iclick's Avatar
iclick
iclick is offline
You mean the right side? If I'm understanding this right, the threads in the forks that hold the studs have stripped? Is this correct?
If so, I think I would just buy a used stock fork leg on Ebay, which shouldn't cost much. People buy chrome legs and sell their perfectly serviceable stockers for low prices. I don't know if tapping into the aluminum at that point would compromise its structural integrity or not, but I think the small chance would be more than I would want to risk considering the safety implications of a failed part in that location.
OTOH if only the studs are affected you can replace these, as they screw into the fork legs. The clamp is held on by two nuts that screw into these studs.
Old 05-12-2012, 05:58 PM
chopper king matt
i should of took pics really but the thread has totally gone as in not there anymore
the exact placement of where the nut tightens up to the bottom leg has sheared off as in like a stud snapping when you over tighten it or try to undo it
and thanks for the advice and im pleased its a stud as it looked like it was cast as a part of the actual leg
Old 05-12-2012, 06:43 PM
chopper king matt
also just wondering if this was something to do with the slammer kit ive just fitted as i think ive gone over a pot hole and its shocked the front end and snapped the stud ?
Old 05-13-2012, 03:46 PM
NCraqz's Avatar
NCraqz
NCraqz is offline
Hellicoils are also worth looking into? Cheap and solid way to fix stripped out threads if there's enough metal left
Old 05-13-2012, 04:10 PM
1HarleyGuy1's Avatar
1HarleyGuy1
1HarleyGuy1 is offline
That must have been some pot hole!!!!!!! (I'd be checking the tire and rim too)
1HarleyGuy1
TheBanditColorado
EVO
27
10-11-2015 06:47 AM
Dieselvol
12-04-2014 10:10 PM
teeboz
02-05-2012 08:43 PM
HDJOE60
08-08-2009 07:51 AM
The Baron
01-23-2008 11:00 PM
Quick Reply: bottom leg thread snapping clean off
