true duals....python or drago or V&H
I am looking at changing to true duals on stock 2008 road glide..
currently running python slip ons.. i will keep them for now...see what they sounds like with diff exhaust... i had python longs shots on my wideglide...so i went with them on this bike..
looking any info on what people might know between python and drago and V&H head pipes..
much sound or performance difference between the 3?
any put out less heat than other.....stock setup cooks my leggs....better since i put heat shields for my leggs....but still HOT !!
Just had this same situation. My rear exhaust manifold broke, and I used that as an excuse to go to Vance and Hines true duals. Got rid of that down tube from right side, and that reduced much of the heat.
I kept the Vance & Hines slip ons, and just added the pipes.
Bike runs cooler, sounds much deeper and a bit louder, and passenger gets a bit less heat too.
Only cost me $100 more than just replacing the exhaust manifold, and I like the look much better without the down tube.
I had a fuel controller and got a fresh set of settings from V&H. Only have a few hundered miles on it, but am pretty happy.
It seems as though I lost a bit of low end torque with the true duals. Might need to revisit the new settings.
No experience with the other brands.
Don't buy any headers that don't have ceramic coating inside and out. You won't get any heat mitigation w/o it. I run Rush true duals:
http://www.directharleyparts.com/exh...ng-p-3954.html
http://www.harley-performance.com/harley-exhaust.html
http://www.vanceandhines.com/store/t.../headers/16749
http://www.pythonperformance.com/pro...roduct%2F79956
Of the three you listed I would go with Drago's because they're ceramic coated inside and out, AND they have the O2 sensor bungs in both sizes, so if you ever change your mind on tuners and go with sideband sensors you're covered. Also Frank is a great guy to deal with.
Just my $0.02
Just my $0.02
liked python i had on wide glide and heard lots of good things here about drago and frank
any input on anything i should be looking at besides drago? right now they are the frontrunner...cant complain about there prices either and feedback on there customer support on many threads i have read..
2 - reduce heat
3 - increased housepower
4 - looks
5 - envy of those that have all of the above
