132db Replacement Horn
Also available here for $7: http://www.ryderfleetproducts.com/ry...oductDetail.do AND http://www.ryderfleetproducts.com/ry...oductDetail.do
I had the HD airhorn installed and it always sounded like a sick duck. I removed it (leaving the relay installed) and bought 2 of the Freeway Blasters, one high note and one low note - love the harmony! I wired them in parallel, mounting the first one under the original cowbell and I mounted the 2nd one on the flat plate of the frame immediately behind the motor.
I get folks' attention....
I replaced my stock horn nearly two years ago with a Fiamm model just like this.
Going a step further, I installed the sister high-tone horn back behind the rear cylinder on the metal plate that separates the engine compartment from the battery compartment. You could actually install the sister horn just about anywhere you have room to install it. The sound will still get out just fine.
On my 2010, I used one of the existing holes in the metal plate to bolt the horn in place. Then just rigged-up some wiring with spade terminals, plus included an automotive relay to feed the horns when I hit the horn button. The signal from the original horn wires is what I use to energize the relay, then the relay provides the voltage/current flow to the horns.
When I hit the horn button, my hi/lo horns sounds like a loud car horn. I've had the Fiamm air horns in the past and they are great, but I decided to stay with the electric horns on this bike, and these were available at any auto parts store for about $15 each. By the way, no issue fitting them under the stock horn cover...although I got rid of that ugly thing a long time ago.
