what fork oil you guys runnin?
Old 05-08-2012, 01:31 PM
dirtracer27x's Avatar
dirtracer27x
dirtracer27x is offline
Default what fork oil you guys runnin?
going to change out forks to black ones and was wondering what fork oil i should use.i only ride 2 up 10% of the time and im a big guy at 300lb.my older 2000 roadglide has the air assist front,wich im doin away with and installling a 07 blacked out front end.but the stock seems to have alot of dive and pretty rough.thanks
Old 05-08-2012, 01:36 PM
hairbone's Avatar
hairbone
hairbone is offline
30wt and in 2000 hd called for a fork fluid change at 10k, now they call for a change every 20k.
Old 05-08-2012, 01:42 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 15,379 Likes on 4,829 Posts
I got rid of my fork oil ( a little in the very bottom) by using progressive sus. shocks, no more maintenance, and much better ride
Old 05-08-2012, 02:07 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
I use this in the rear shocks. one bottle per shock.
http://www.lubegard.com/~/C-112/LUBE...uid+Protectant
Old 05-08-2012, 02:22 PM
fordhd2005's Avatar
fordhd2005
fordhd2005 is offline
Do a 50/50 mix with the standard and screamin eagle fork oils. You should find that you will have less diving and tighter handling.
Old 05-08-2012, 02:26 PM
Ronp42's Avatar
Ronp42
Ronp42 is offline
Account Retired
My 2010 SM calls for fork oil to be changed at 50K. I changed mine at 10K to screamin eagle because of the front end dive. Works great now!
Old 05-08-2012, 02:30 PM
frog13's Avatar
frog13
frog13 is offline
I'm your weight and just changed out my front end to black on my SG. Used the Screamin' Eagle Heavy Duty and it made a lot of difference in a positive way, not sure why you would want to mix it with standard but maybe someone has a reason. They also have a heavier racing fluid, not sure how that would be.
Old 05-08-2012, 03:11 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
I'm a little lighter at 220 and have had SE heavy in since the very beginning. It's better than the stock oil that was in it originally and I did the chrome sliders at the same time to make it more cost effective.
Old 05-08-2012, 03:43 PM
jjnoble's Avatar
jjnoble
jjnoble is offline
I'm about to put 15w in my 09 SG. Some say that is a bit heavy others say it is great. I don't know yet.
Old 05-08-2012, 03:46 PM
Sailrider 1's Avatar
Sailrider 1
Sailrider 1 is offline
5W Amsoil shock therapy with Ricor Intiminators modified by Fabrik8R and racetech springs. Best front suspension on a HD I have ever ridden.
Quick Reply: what fork oil you guys runnin?
