Boom audio in streetglide
From Sonic
Is this the one?
For over 25 years, Punch amplifiers have set the standard in the car audio amplifier industry and they continue to do so today. It's the reason that they have become the most popular amplifiers in the world. Each of the Punch family amplifiers reproduce sonic perfection along with impressive power in a compact chassis.
The P300-2 is a solid choice if you're looking to drive coaxial speakers and/or one 4-ohm SVC subwoofer. With proven PUNCH technology, the P300-2 delivers real Rockford Fosgate power from a small footprint. This amp is small enough to easily fit under any seat.
Is this the one?
- Punch Series 2-Channel Class AB Car Amplifier
- RMS Power Rating:
- 4 ohms: 75 watts x 2 chan.
- 2 ohms: 150 watts x 2 chan.
- Bridged, 4 ohms: 300 watts x 1 chan.
- Total Rated RMS Power Output: 300 watts x 1 chan.
- MOSFET power supply
- Top mounted LED power, thermal, and protection indicators
- Audiophile grade speaker connections
- 2 channel operation
- Heavy duty aluminum alloy heatsink for maximum heat dissipation
- RCA level inputs
- Screw terminals
- Variable high-pass filter (50-500 Hz, 24 dB/octave)
- Variable low-pass filter (50-500 Hz, 24 dB/octave)
- CEA-2006 compliant amplifier
- Frequency response: 20-20,000 Hz
- Dimensions: 9"L x 7-5/8"W x 2-1/4"H
- 8-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
- 1-year SonicElectronix.com warranty
Is this the same thing, they don't look the same.
CEA-2006 Compliant:
Number of Channels: 2
Rated Power
(RMS Continuous Power): 100 Watts x 2 @ 4-Ohm
150 Watts x 2 @ 2-Ohm
300 Watts x 1 @ 4-Ohm Bridged
Total Power
(Sum of Rated Power): 300 Watts
Dynamic Power
(PVC/PowerCube® Measurement):
Bridgeable: Yes
Efficiency (average):
Crossover Controls: High-Pass: 50Hz - 500Hz @ 12dB/Octave Butterworth
Low-Pass: 50Hz - 500Hz @ 12dB/Octave Butterworth
CEA-2006 Compliant:
Rated Power
Total Power
Dynamic Power
Bridgeable: Yes
