Stage 1 with stock cover (help)
05-03-2012, 11:48 AM
I installed the Arlen Ness Big Sucker Stage 1 primarily because I want to use the stock cover. Install went great but the black gasket around the football cover falls off with nothing to mount to. Did I do something wrong?
05-03-2012, 11:50 AM
yes you tried to reuse the black gasket.. there's nothing for it to seal to?
its meant to seal the factory backing cover to the football cover throw it away you don't need it
05-03-2012, 11:55 AM
Quote:
Originally Posted by
RDKNG2011
But it just doesn't look right without it. Oh well, I'll remove it. Thanks
05-03-2012, 12:09 PM
I put a little contact cement on mine, works fine
05-03-2012, 02:40 PM
OEM backing is gone. You don't need it.
05-03-2012, 02:48 PM
criyi
it looks better without it
05-03-2012, 03:11 PM
keep in mind...that cover is really good as sucking in hot air which has been heated by the cylinder heads...on hot days...you might want to throw the cover in your saddle bag.
jackets
03-26-2012 04:41 PM
skipper469
Softail Parts
09-14-2009 12:15 PM
skipper469
Dyna Parts
09-13-2009 09:09 PM
twilliams
Exhaust System Topics
06-27-2007 09:25 PM
skottyd
10-24-2005 11:10 PM
