The next performance upgrade that will provide the best bang for the buck?
Old 05-02-2012, 10:52 AM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
Cams, shocks, forks, seat, bars. no real order.
Old 05-02-2012, 11:22 AM
iclick's Avatar
iclick
iclick is offline
Originally Posted by OldFordTrk1
Looks like cams are the most popular. I suspected it might be.
That one-word recommendation ("cams") should be amended as "the right cams for your riding style." Put the wrong cams in the bike and you may end up with diminished satisfaction. Do your research. Also, be advised that if you do take that step up you may need a different tuner, or at least a revamped tune to fit the profile of the new upgrade.
Old 05-02-2012, 12:14 PM
joflewbyu2's Avatar
joflewbyu2
joflewbyu2 is offline
XiEDs for enrichen closed loop where you spend most of your riding time in. Fuel pack only helps open loop not closed loop. Less than $100 and well worth it.
Old 05-02-2012, 12:37 PM
OldFordTrk1's Avatar
OldFordTrk1
OldFordTrk1 is offline
I thought the fuel pak used the stock ecm in a closed loop fashion. Does the fuel pak not use the O2 sensors to to make adjustments while riding?
Old 05-02-2012, 08:43 PM
North Star's Avatar
North Star
North Star is offline
You never mentioned if you have aftermarket slip ons. There are a ton of good choices out there, and no shortage of used ones around. Most will add a bit of power vs the stock mufflers.
Old 05-02-2012, 09:09 PM
littlebear's Avatar
littlebear
littlebear is offline
Yep, just put on the high flow air cleaner and the Harley download which my dealer did for free, was going to get a PCV, but the download and A/C have made a big improvement, should have done it sooner.
Old 05-03-2012, 05:43 AM
OldFordTrk1
Still have the stock slip ons but quite happy with the sound. Would I actually feel the difference in performance with a new slip on?
Old 05-03-2012, 06:56 AM
Geezr Glidr's Avatar
Geezr Glidr
Geezr Glidr is offline
Yes, I think you definitely will. I could tell the difference on my 2011 103 Limited Ultra, as soon as I did Vance & Hines Power Duals, and Vance & Hines High Output slip-ons. Plus, the High Outputs sound great. Nice big deep rumbly bagger sound, but nobody has any problem riding behind me.
mhsmith451
10-24-2013 06:59 PM
FinalShot
10-01-2013 06:56 PM
OldFordTrk1
05-01-2012 10:07 PM
frog13
09-23-2011 10:07 AM
2014streetglide
06-20-2010 04:15 PM
Quick Reply: The next performance upgrade that will provide the best bang for the buck?
