cam and vibes
Disclaimer: I'm not a mechanic.
Yes...Rougher idle=more vibration...Depending on cam.
The way it was explained to me, the cam can't do everything perfect. If the cam is designed to "come on" late, as in high RPM, then it will likely idle rough. Listen to any dragster before take off and you'll hear what I'm talking about.
I have a mild Andrews cam. The idle is only slightly rougher...Hardly noticeable. However, it runs WAY smoother at higher RPM's...Velvety smooth at 3000 to 3500.
When I installed my SE204's and tuned the bike it actually smoothed out the bike quite a bit. Sure it has more of a lope at idle but when it is going down the road it runs so much better. If you put cams in be sure to get it tuned and you will not be disapointed with the results.
I forgot to look, did you put the 204 in a stock 96"?
