Fullsac install
Fullsac install
i finally got around to installing my Fullsac dual-conversion today. this kit is excellent! you cant beat the price for what the end result is (true duals). the directions say that the install should last 1-2 hours, it took me and a friend about 2.5hrs. i like to take my time with installs though.... fit/finish is great, sound is awesome and the look is very good (as long as you can get your heat shields lined up tight- as i did). i really didnt notice any heat dissipation- probably because it was like 50 degrees out. power feels up slightly- but it may be in my mind.
for anyone who wants true duals for a great price and is even SLIGHTLY mechanically inclined- i would definitely recommend it.
RE: Fullsac install
I ordered my Fullsac conversion kit last week. Looks like another week before I get it - UPS screwed up.
Could not resist buying this after reading the reviews and seeing the 100.00%rating on Ebay (400+ sold).
Anybody havescanned or .pdf instructions for the install???
Would like to get a jump on the details. '05 Ultra FLHTCUI.
THANKS - Dave H. dchoran@athenet.net
RE: Fullsac install
Dave- its very straight forward. remove bags, mufflers and heat shields. then basically remove all brackets/clamps/nuts other than from the middle of the front pipe. once all of the hardware is removed- simply drive the H-pipe rearward with a hammer and block of wood. once its all removed- a little massaging of the stock pipes may be necessary and reinstall it all. its very simple.
i was leery of the whole 'hammer/block of wood'- but it worked.
RE: Fullsac install
You will find installation instructions http://www.fullsac.com/products_exhaust_install.htm
RE: Fullsac install
I also installed Fullsac True Dual conversion kit on my '07 ULTRA and it is a sweet kit. Also sent in my stock '07 mufflers so Steve can perform his magic re-coring them. Should have them back on in a week or so and with the addition of S/E stage 1 aircleaner and a K&N filter I can't wait to get it on Dyno and tweek it in for Daytona.
Also have SERT installed. This one won't ping no more.
