70mph...5th gear or 6th??
Old 04-30-2012, 05:36 PM
Nirvana's Avatar
Nirvana
Nirvana is offline
If I'm maintaining speed at 55 or greater, then I go to 6th when I reach my desired speed. If I need to accelerate/decelerate for any reason, I go back into 5th. I only accelerate in 6th if I'm over 70, on flat roads and then only gradually.
Old 04-30-2012, 06:10 PM
zfdtruckman's Avatar
zfdtruckman
zfdtruckman is offline
Any long stretch over 3 grand I go to 6th. Even if I get down to 2 grand, on the expressway, 6th gear with my 110 gets up and hauls without a hitch.
Old 04-30-2012, 06:16 PM
trosel238's Avatar
trosel238
trosel238 is offline
With the 255 cams my 103 pulls fine even in the mid 50 mph range. Can't imagine needing 5th gear at 70 mph
Old 04-30-2012, 06:21 PM
Idaho Spud's Avatar
Idaho Spud
Idaho Spud is offline
2011 RKC with a stage 1. At +60 mph I go to sixth and leave it there. Only if I had to pass in a hurry would I down shift.
Old 04-30-2012, 06:23 PM
paulgaines319's Avatar
paulgaines319
paulgaines319 is offline
6th gear is there for a reason.. As long as there is nothing slowing you down, like wind, hills curves, Ect, above 65-70 drop her in 6th, and go. Do your break-in first,then some, and a couple oil changes, Then your good to go.. If you feel "lugging" pull her out of 6th and continue in 5th until it's safe to go back into 6th. Don't fear 6th it's a wonderful thing, as long as you watch your engine speed.
Old 04-30-2012, 06:28 PM
Inspector 12's Avatar
Inspector 12
Inspector 12 is offline
What ever gear spins the engine at about 3000 rpm. My stage II 103 with SE 255 cams likes it there and gets great mileage.
Old 04-30-2012, 06:37 PM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
Received 1,301 Likes on 781 Posts
Originally Posted by 2black1s
55 mph in 6th gear as KCFLHRC stated he likes is way too hard on the engine for my liking. Additionally, you have very little throttle response either up or down at such a low rpm in 6th gear.
On my 11 Limited I would agree with you. But the RKC is 100 pounds lighter and pulls strong in 6th at 55 mph. It's definitely not lugging and has plenty of throttle response.
Old 04-30-2012, 06:50 PM
dgdamore's Avatar
dgdamore
dgdamore is offline
Way better milage in 6th. Get there and keep it there as much as you can. (If you care about milage)
Old 04-30-2012, 06:54 PM
Pete6114's Avatar
Pete6114
Pete6114 is offline
I'm still braking my 12 UL in, and stay between 2500 ans 3800 rpm for now, regardless of speed or gear.
Once broke in, i usually keep between 2500 to 2800 rpm.
Last bike i had ( heritage 103) 6th was just for cruising at steady speed..flat/not much head wind. Anything other then that, i had to drop to 5th.
New bike with 255,s...6th is much more usable. I will keep at above mentioned rpm's to keep noise down (louder pipes), get decent MPG and keep engine wear down. I have no need to rev at high rpm's and prefer to stay below 3000.
Each to his own....
Old 04-30-2012, 06:59 PM
2black1s's Avatar
2black1s
2black1s is offline
Not necessarily or always true. There's more to MPG than simply engine RPM. The additional load associated with 6th gear vs. 5th gear plays a significant role.
Quick Reply: 70mph...5th gear or 6th??
