Antennae whip ... oops ...
I just installed a CB radio on my Road King ... the antennae (3 ft)fits on a license plate bracket ... in the wind, it starts whipping and whacks my wife on the head (good reason to wear a helmet ) ...
I guess my options are (and no, removing my wife off the back is not an option):
1) smaller antennae ?
2) longer bracket to move the antennae back ?
3) add some sort of shaft to make the lower part of the antennae stiffer ?
Any thoughts?
thank you!
( and Happy New Year!)
Any thoughts?
thank you!
RE: Antennae whip ... oops ...
Had the same problem with the antenna on my Streetglide. After I got poked in the eye I put an antenna ball on the end. On the road it would whip around and hit my passenger. Solved it by putting the antenna into the windshield with an antenna strip I got from West Marine. Radio waves are line of sight so you should be able to do something similar with a CB. A good electronics store should know. I tried a shorter antenna but reception was not good due to passengers blocking transmission. The antenna in the windshield works way better than the antenna supplied with the Streetglide.
Good luck.
Good luck.
ORIGINAL: rvisdew
Any thoughts?
thank you!
Any thoughts?
thank you!
You can get a small "rubber duckie" antenna, but it won't receive very well and transmit even worse. I don't know if you can move it or not, but that's probably the best option. Consider going higher with it if possible, not just farther back. You shouldn't attach anything to the whip to stiffen it.
(Just curious: how does it hits your wife if it's 3' long mounted on your license plate? Do you ride backwards a lot? My whip antenna, while not for a CB, blows backward when I ride.)
When you say you "putting the antenna into the windshield with an antenna strip" do you mean in the batwing or are you talking about doing something else. What is the manufacturers name of the antenna you are using?
I think these are the antennas that bobo06 mentioned. There are 4 different License Plate mounted antennas ranging from 1' to 4' lengths.
http://www.jmcorp.com/SeeProducts.asp?PF=31
