PBR 300x2 settings question
I have a Reckless fairing on my Road King, and used 3/8 thick high density foam from a door mat to line my outer fairing.
Using this foam from a door mat was recommended by a high end stereo installer I know that builds some awesome systems. He says the foam right behind the speaker absorbs the pressure wave coming off the back of the speaker.
I can honestly say it works. I used the system a couple weeks before I lined it with the foam. After lining the fairing the system sounds much cleaner, especially at higher levels.
A very cheap mod that actually works.
