I just ordered this tire thinking it would fit because it is just a little wider than the 140. Has anyone done this and can confirm that there will be enough room. Or do I need to cancel it and get the 140?
Have a 150/70 18 on the rear of my 08 SG with no issues. Current 150 Pirelli is wider than the 150 Metzelers that I had run before even tho they are both listed as 150s.
Thanks
I've been wondering the same thing.... I emailed Dennis Kirk, waiting to hear back.
Here is what they said.
"The 140/90-16 is 5.59" wide and the 150/80-16 is 5.91" wide. You'll need to measure to see if you have enough tire/swingarm clearance to use the wider tire."
Treat that info with caution! I have some experience of using alternative tyres and have found that when fitted to a wheel the actual width seldom corresponds to the width on the sidewall or in the brochure.
As one example my 140/90 Avon Venom claims to be 143mm wide, but measured 139mm. My 150/80 measured 153mm. That was their H speed rated version, but their V rated is quoted as being 157mm wide.
There is no certainty what the actual fitted width is, so keep a little in reserve when trying to squeeze in that even wider tyre!
