Need advice on air valve problem
Just bought a new Road King Classic (400 miles), with the optional tubeless spoke wheels. First bike I've owned. The valve on the back wheel is really hard to get to, and I needed some 90 degree attachment to get air into the tire. You'd think Harley would design a 90 degree valve into this wheel instead of making you buy extra gauges and attachments just to put a little air into the tire. Anyway, I used the flexible value extention ($10 from Harley) after a bit of manuvering screwed it in a filled up the tire to 40 lbs. Went riding and on the way home noticed the back tire swimming. Managed to make it home, and by then it was pretty much flat though not completely. Could not find any punctures. Tried to put air into it, but it seems the valve won't let me put air into the tire. Do I need a new stem? I'd hate to remove the tire just to put a new valve on. Anybody have any ideas on what best to do next?
The dealership told me not to use those extensions as they leak. Guess its true. Break down and do what I did. Buy the HD gauge (you will eventually anyway). For the rear, I take off the bag and almost lay down to get to it. But it beats some of the alternatives. When you change tires, then have the 90° valve stems put it. Just don't use extensions.
It depends on the condition of the valve.
The source of this problem is the tight clearance, and as mentioned above, many of us use the stupid h-d gauge to fit it.
extensions, etc can throw the wheel off balance ( by adding weight) and H-D stays away from 90º as they can get sheared off-- and a liability problem.
and I see why as I lost a valve to some road debris once at high speed.
1.) never ride with a low tire "just to make it home", you could easily go down.
1.b) or damage the tire/wheel beyond repair
2.) fix a flat in the saddlebag can be handy ( always tell the reapir guy as the stuff can cause issues, such as fire if he has a butt hanging out of his mouth)
You could always try the dealer and say "i dunno" it's under warranty, right ?
mike
mike
The billet ones from Motorcycle Anchor are complete replacements that can only be installed when the tire is off. They are absolutely bullet-proof. Sealed with an o-ring and secured with a nut they are rock-solid. Also, they aren't exactly 90* so they give you easier access than if they were totally flat. They're light weight and probably weigh less than the rubber crap that comes with the wheel. Had these and loved them. Changed the wheels eventually because I did not love them.
