muffler clamp moisture leak...
Old 04-25-2012 | 07:29 PM
Brancajd's Avatar
Brancajd
Default muffler clamp moisture leak...
I recently purchased a 2012 FLHX (street glide). I removed the stock mufflers and put on a set of fishtail slip ons. I reused the original muffler clamps (brand new bike with 50 miles on it) and torqued them according to spec 45 -60 FT-LBs. Started the bike (cold) and noticed moisture coming out the tail pipes...I understand this is normal, just like cars/trucks. However, I noticed on the floor on both sides of the bike, small droplets of water, a "mini puddle" about the size of a 50 cent piece directly under both muffler clamps. I already had the clamps at max torque...so....right now I have them a 75 ft-lbs and it's still doing it. This is only on cold starts when the bike has been sitting over night. Any suggestions?????
Old 04-25-2012 | 08:00 PM
redman2636's Avatar
redman2636
I've never had a bike that didn't lose moisture at the clamps. I believe that's totally fine.
Old 04-25-2012 | 08:07 PM
Iceman24's Avatar
Iceman24
Shouldn't see any moisture/soot @ clamps...when you installed the new pipes - did you slide them "over" the slot far enough & seal with HT silicone (i.e. liquid copper). For one - these clamps are also "crush" type & even though new they will compress when re-used. Also, where did you get that pipe/clamp torque value (45-60 ft/lb)??? Most pipes are in the 38-43 ft/lb so you've probably squeezed the seam so far it's bent & leaking...you might have to remove them & get the pipe/tube expanded to same size as pre-install...
Old 04-25-2012 | 08:16 PM
BenRK05's Avatar
BenRK05
I just went thru this very same thing. If you read the entire muffler section in the manual. It states that the exhaust clamps are a one time use only part. You will need new ones to get a proper seal. At the dealer they will run you $17.99 for two. The rec torqe is 40 to 60 lbs.
Old 04-25-2012 | 08:21 PM
orbit's Avatar
orbit
Remove the mufflers/clamps. Run a small bead of high temp copper silicone, either in the inlet to the muffler or at the tip of the head pipe, as suggested above. Reassemble.
Let the silicone cure for a bit. A day would be optimal.
That should solve the water seepage problem.
Old 04-25-2012 | 08:28 PM
mkguitar's Avatar
mkguitar
yup, torca clamps are "one-use" the number of miles doesn't matter, it's the amount of force used on install and how far they deformed.
When you install new clamps, go as loose as you can with good seal ( lower end of the torque range which is 38~43 ft lbs), then the next time the clamps may be re-used. I get 2 or 3 uses out of them, and always have some in stock, just like oil drain o rings, derby and primary gaskets.
Mike
Old 04-25-2012 | 08:35 PM
Brancajd's Avatar
Brancajd
I got the torque value from my manual 45-60 ft/lb. I started on the low end and worked my way up...I will pick up new clamps from the dealer.
Old 04-25-2012 | 08:51 PM
Brancajd's Avatar
Brancajd
in fact...all of the HD muffler install pdf's I've seen on the net have the torque values at 45-60 ftlbs.
Old 04-25-2012 | 08:54 PM
Brancajd's Avatar
Brancajd
not saying there could be more values, but of all the ones I've seen, it's been 45-60ftlbs.
Old 04-26-2012 | 06:10 AM
RK Joy's Avatar
RK Joy
There is nothing about that clamp or the design of the slip on fitting that would make it water-tight. Bottom line: do not worry!!
Quick Reply: muffler clamp moisture leak...
