Cams Again
Cams Again
Hello everyone. Have been on this site for awhile but first time looking for some advice. Have a 09 EGC. stage 1 now. Ride mostly 2 up. Been doing a lot of reading on the cam threads but is anyone running the SE 253 cams. If so how do you like them and campare to the 255 or any others.
thanks for the imput
253 cams are an odd grind. Not too much to compare them to, nor is there any particular application where they would be a first choice. They have an unconventional profile, not a particulary good high hp cam, nor are they a torque cam. They were used in the CVO 103 motors, which was a fairly low compression motor with big chamber heads. Look elsewhere for a cam. They're nothing like the 255, which would be a good choice for your bike.
