O2 sensors
22mm box end wrench for the O2 sensors.
Easier to take the pipes out then remove the sensor.
If the sensor is really cranked in, you may screw up the threads taking them out.
I found the threads on the sensor to be a little soft and easy to muck up.
New ones are about $45 at the dealer. (Don't ask how I know)
Careful not to get any penetrating oil on the sensor tip. (They don't recommend using anything)
If the bike is fairly new, they should come right out just using the wrench.
