Fairing amp for Limited
Looking for a fairing amp for my '12 Limited. I know I will have to move the CB module. There seems to be a few ways of doing that.
The problem I am having is finding something that will work with 2-ohm speakers, will drive all four speakers, and will have a simple plug-and-play install besides the power wires. I don't want to have to cut or splice anything.
At first i was going to order the Boom! fairing amp, but the product description eluded to a wire harness that might be needed, but without a part number. I don't want to spend $400 on an amp if I don't know all the parts I need.
I also want to keep my HD Boom! speakers, so the Rokkr 500 watt amp is too strong.
The only one I have found so far that might fit my criteria is from Hogtunes, but the description isn't very helpful with regards to a plug-and-play wire harness.
http://www.phatperformanceparts.com/.../4405-0231.htm
Suggestions?
Suggestions?
Suggestion: If you haven't already done so, go to Hogtunes' website and you'll find an in-fairing amp that meets your requirments.
IMO, "plug and play" is grossly over-rated when it comes to installing an amp. The hardest part is running a power wire (w/fuse) to the battery and installing the ground wire for the amp. Using the OEM speaker wires as inputs to the amp, and supplying new wires for the outputs from the amp to the speakers is basically buying some simple crimp terminals and attaching them to readily available 16/18 ga. speaker wire.
Good luck with your project.
Carl
PS: It helps a lot to have the HD Service Manual's wiring diagram to understand the audio wiring on the bike.
Carl
Pioneer, I am in the same boat sorta speak that you are. If your wanting it louder then the amp will help, if your wanting more bass then it want. You need to call Biketronics. They make a plug and play amps that have a lifetime warranty and there speakers sound awesome. Ypo can buy a set of 6.5" speakers and a amp combo for $550 that will blow you away with a full 30 day money back gaurentee. I have a brand new set of Boom Speakers that I'm not happy with. I know , I know, I'm the only one here that don't like them but they won't carry any bass, there just louder.
As an industrial electrician, I have found that the more splices and crimps you have in your wiring, the more problems you have. That is the reason I don't want to splice anything. The power and ground will not be a problem, I just don't want to start hacking up the leads in and out of the factory stereo/wire harness.
P.S. Got mine, brand new on EBay, for 100 dollars less than buying it direct from Hogtunes.
Nevertheless, Hogtunes can supply what you want in terms of a complete wiring harness.
Carl
I have a '12 Limited as well and wanted to do all 4 speakers and an amp- I am think I am going to go with this
The Bagger Nation Ultra “Supreme” 75EX System
http://www.baggernation.com/products-stereo.htm
comes with the RF amp, 6.5" speakers for the front, 5'25" for the rear, speaker adapters, wiring harness and instructions
benson1603
Audio Systems
02-09-2019 01:54 PM
Harleypingman
Audio Systems
131
06-14-2016 07:03 AM
