Road King sound
amazing loud is subjective.. if you want as loud as possible you need true duals with as little baffling as possible many think rineharts are one of the loudest.. having the rineharts i would say vance and hines seems a bit louder to me
either way anytime you change the pipes you are going to need a aircleaner and a tune or at least xieds
another idea might be a cam swap.. put 255s in my bike but it seems just about any cam makes a bike noticeably louder i sure noticed it in mine
good luck
good luck
good luck
good luck
http://www.harley-davidson.com/gma/g...bmLocale=en_US
And how about the rinehart Slip on mufflers.
I would like your feedback
Also do u recommend the heavy breather over the above Performance ventilator kit??
Thanks
good luck
good luck
Well, not with just slip ons.
Thx for ur recommendation well to be honest The first thing I'll be installing is the following:
Thanks
Thanks
If I was after a really aggressive pipe, I'd probably go for something like an RB Racing 2:1. Doesn't get much nastier than that.
As for the AC, I myself avoid open element AC's due to the amount of rain we get here. I think they make a sock for the heavy breather that helps or eliminates that issue. May or may not be a concern where you live.
Just a comment from someone who's been there, make sure that's what you really want. My 2000 Buell X-1 came with a Force pipe with no baffle and it would positively make your ears bleed. The first thing I did was get a baffle for it, and even with the baffle it'll leave your ears ringing after a 30+ minute ride. It sounds awesome, like a freakin' hemi Cuda running open headers. Heads spin all over the place trying to see what's going by. But dang, it does get old on a long ride. I learned there can be such a thing as "too loud", LOL! I've got 4" Rineharts on order for my Glide specifically because people said they have a deep throaty sound, but are not obnoxious when cruising on the freeway.
I like an ear bleeding roar
loud pipes
I have a '12 Road King also,2460 miles.Put on Rush slipons with 2.5" baffles SE breather and Power Commander V.
Ihad the 2.5" baffles in my '07 Softtail and the sound was awesome.
I ended up removing the baffles in my RK cause the cat converter makes it super quiet.Sounds good now without baffles but unless you remove the cat as stated earlier post your King won't have the "loud" you're wanting.
Saying that from experience on my King.
Go true duals if you want loud,the cat will stop you from getting the sound you seem to want.
Good luck and nice bike,I love mine.
