Clutch Friction Zone ?
I adjusted my clutch recently and it start to grab where i want it and it has not slipped at all since adjustment.
However, when it starts to grab it doesnt "Bite" well, its kind mushy. Also, it takes a long time to go through the friction zone.
1) did i adjust wrong
2) how do i make it "hook up" better?
thanks.
thanks.
I don't think the "bite" or "hook-up" as you say has anything to do with the adjustment. That charactristic is in the clutch design.
As long as you have some freeplay in the clutch, in the lever, the clutch engages/disengages as you like, and the clutch doesn't slip, then you have it adjusted within an acceptable range.
Changing the "bite' or "hook-up" would require new clutch components or experimenting with the oil type you are using in the primary.
Let's just say there are a lot of opinions on this. Personally, I never want to "live in the friction zone" unless it's absolutely necessary. I want my clutch in or out with a minimum of time in the friction zone.
It's been a while since we've had this discussion.
[quote=2black1s;9707020] I want my clutch in or out with a minimum of time in the friction zone.quote]
Thats the bridge im attempting to cross. It takes to long to ge tthrough my friction zone and i dont care for it. I like the effort it takes for me to pull the clutch, but i much more prefer my Dad "03 RKC
...Also, running stock lube from HD, planning on changing to something better when i do the 10K (im at 8 right now)
Lastly, sorry for the disapointing thread...lol
Now this is a whole 'nuther topic! And the topic I thought this thread would be about when I saw the thread title.
[quote=BuckeyeUltra;9707393]
Don't sell yourself short. This was a valid question and invited input that you need. There were some good posts here, and everything you learn on HDF will enable you to become a better and (hopefully) safer rider.
One of the posts mentioned the primary fluid. That certainly will affect how a clutch "bites". I run Redline primary oil in my primary. While it is a synthetic, it has a balance of friction enhancing substances alowing for proper clutch operation. Maybe have an indy pull the primary cover and do an internal clutch adjustment as well as a fluid change and see where your at. Sometimes an internal clutch adjustment changes things for the better. The Redline shockproof transmission oil really makes a difference too, making the HD tranny shift far smoother than it does with HD Formula plus. But that's another topic.
Keep asking questions. The only dumb ones are the ones you fail to ask.
