Clutch Friction Zone ?
Old 08-16-2023 | 10:58 AM
IanD's Avatar
IanD
3rd Gear
Originally Posted by 2black1s
I don't think the "bite" or "hook-up" as you say has anything to do with the adjustment. That charactristic is in the clutch design.
As long as you have some freeplay in the clutch, in the lever, the clutch engages/disengages as you like, and the clutch doesn't slip, then you have it adjusted within an acceptable range.
Changing the "bite' or "hook-up" would require new clutch components or experimenting with the oil type you are using in the primary.
My FLHCS was exactly the same - a very late bite, so checked clutch adjustment and fluid and it turns out that they are ‘just like that!’
My previous FLHTCU was just perfect so I added Oberon Levers and now problem is totally solved! Just perfect 👍
Old 08-16-2023 | 11:07 AM
Keithhu's Avatar
Keithhu
Hoping the OP figured it out in the 11 years since this thread was started. Welcome to HDForums, from Michigan!
Old 08-16-2023 | 11:21 AM
IanD's Avatar
IanD
3rd Gear
Haha! Hopefully😀 Thank you for the welcome from Essex, UK
Keithhu (08-16-2023)
bladeguy
05-20-2021 10:36 PM
snookedsteve
EVO
01-09-2016 05:38 PM
texacon
07-18-2011 08:32 PM
baron3547
10-05-2006 01:35 AM
ULTHD
05-20-2006 10:05 PM
