103's with oil comming thru breather?
Old 04-23-2012, 04:49 AM
hardwork2's Avatar
hardwork2
hardwork2 is offline
Default 103's with oil comming thru breather?
Anyone else having this issue? I had a 3 88 inchers that did this then my last one on a Ultra I had upgraded to a 95 and it quit. Now It seems my 103 is puking oil thru the breather.
I thought I'd ask you'll before I ask the shop to get a idea if this is normal. you'd think since they got the problem resolved in the 95 cu in they'd carried it over to the 103's,
Old 04-23-2012, 04:52 AM
slammed05fatty's Avatar
slammed05fatty
slammed05fatty is offline
my fat bot used to do that, and its was time to change the filter, and then i put heavy breather on and that solved it all
Old 04-23-2012, 04:57 AM
96roadking's Avatar
96roadking
96roadking is offline
nothing like that so far, but then I've only gotten 500 miles on her!
Old 04-23-2012, 05:09 AM
cochon's Avatar
cochon
cochon is offline
I haven't had that problem since overfilling my 97 Ultra
Born2cure's Avatar
Born2cure
Born2cure is offline
I rebuilt mine did 103 buddy said I should go gravity. Not really sure what he meant but I guess it blows out the unspent fuel thru hose on bottom instead of putting it back into the cylinder. Also keeps piston cleaner not having the crap building up should of listened. Should of took time to understand better. It's Not always happening but I do notice oils on cam cover then I clean filter and wipe oil off.
Old 04-23-2012, 05:25 AM
Weavr99FLHT's Avatar
Weavr99FLHT
Weavr99FLHT is offline
Several things can cause excessive oil to blow out the crankcase breather into the air cleaner (to be sucked into the intake to burn up - it's an EPA thing).
Over filling oil.
Too much water in the oil evaporating (that's the point of the breathers, to exhaust water vapor, a natural by-product of combustion) - the water vapor brings a little oil with it).
And, I've seen on a few motors, Rings worn with seemingly low miles (when rings are worn, the pressure in the combustion chamber forces air past the rings into the crankcase, and it has to escape somewhere so it exhausts thru the crankcase breather taking oil with it - do a leak down test to determine - that's why upgrading your TC88 to TC95 fixed it - new rings)
Harley provides dealer with acceptable amount of oil loss between oil changes so you dealer will probably say "normal".
Old 04-23-2012, 08:07 AM
Armstronges's Avatar
Armstronges
Armstronges is offline
My 96 does it intermittently. Just kinda learned to ignore it. A drop here a couple of drops there.
Old 04-23-2012, 08:39 AM
racklefratz's Avatar
racklefratz
racklefratz is offline
Just to reiterate what Weavr99FLHT said, at my recent 1K service, I was talking to the tech about things I'd be doing myself, and on oil changes, he warned me not to fill it to the "full" mark on the stick. Leave the oil level a little below that, for the reason you bring up.
Old 04-23-2012, 08:43 AM
crackercap's Avatar
crackercap
crackercap is offline
I have a 2011 limited with about 7500 miles and I have not noticed any so far, pretty much left it stock.
Old 04-23-2012, 08:47 AM
crackers's Avatar
crackers
crackers is offline
My 2011 Ultra Limited did it. They found out not to fill it full. My oil level had to stay about half below the mark then no problems
Quick Reply: 103's with oil comming thru breather?
