WTF! Brand New 2012 Ultra need to open fairing - Recommendations
Old 04-22-2012 | 02:28 PM
mkguitar's Avatar
mkguitar
you have a warranty- just take it in.
if out of warranty- place tube socks over passing lights, put a thick towel on the fender
remove 3 screws and pull out windscreen.
replace center screw-loosely
remove 4 screws in inner fairing
figure out where you will put the fairing, like a blanket on the bench
go around to front of bike- hold fairing
remove center screw, fairing is now loose, pull back slowly, reach in and pull wire from headlight
mike
Old 04-22-2012 | 02:45 PM
bmaier's Avatar
bmaier
Originally Posted by steelerdude1
It's just 4 Torx head (T27) Screws to pop the outer fairing off, It is really no big deal.
EDIT, plus the 3 windshield screws
Plus one, 7 T27 torx screws and 10 minutes
Old 04-22-2012 | 03:06 PM
riteway's Avatar
riteway
Take to the dealer but wait till your first service!! By then you will have a list of things...
Now if you are **** and its driving you crazy then do it yourself...No biggie (really) or yes take to the dealer BUT dont give them an ear full as shiot happens! Save giving them grief over your bigger issues................o~`o.................
Old 04-22-2012 | 03:23 PM
JRandall's Avatar
JRandall
Last time mine was inside the dealership was in 07 with 3 miles on it. If you are at all confortable with a wrench there is not much to working it. Had the fairing off this morning to work on amp, nothing to it.
Unlike a street glide your fairing won't fall off when you take the screws out. Passing lamps hold it up nicely. Just don't forget to unplug headlight. The little reset button just pushes through hole and rubber boot screws on to hold it in place.
Good luck and have fun with your new toy
Old 04-22-2012 | 03:36 PM
bluffalobob's Avatar
bluffalobob
Like others have said, taking the fairing of is easy. I would use it as an excuse to install the garage door opener kit, well worth the time to install. Just toggle you high beam switch and the door automatically opens.
It doesn't hurt to put some old tube socks over the running lights before you start, it will keep you from scratching the fairing.
You'll need a T27 torx, I bought one like this from Sears, it's a lot easier to use than the fold up kind, especially for the bottom screws.
Attached Thumbnails WTF! Brand New 2012 Ultra need to open fairing - Recommendations-t27.jpg
Old 04-22-2012 | 05:41 PM
mike5380's Avatar
mike5380
Originally Posted by z71_fourwheelin
Oil temp is only useful if you do a lot of parade riding or have engine mods that could heat your bike up.
How often is the air temp gauge useful?
Mike
Old 04-22-2012 | 06:39 PM
racklefratz's Avatar
racklefratz
As often as I look at it, which is fairly often. Why?
No such thing as too much information. (don't bother to do the "it's not accurate" thing - I'll worry about that)
Old 04-23-2012 | 05:10 PM
Tripleshot's Avatar
Tripleshot
Next time I pul my faring, I will put in the XM satelite add on and be done with dead air FM out here between cities. And all satelite info shows on the radio face.
Old 04-23-2012 | 06:01 PM
Bushy's Avatar
Bushy
bring it baCK!!!LET DEALER WORRY ABOUT
Old 04-23-2012 | 08:06 PM
JRandall's Avatar
JRandall
Air temp gauge is very close on Dad's UC, but my SG is not even in the ball park. If it's 90 mine says 120. Can't understand the differance, would like air temp guage if it was as accurate as his.
Quick Reply: WTF! Brand New 2012 Ultra need to open fairing - Recommendations
