No fire from the plugs? WTH
Just finished up my hydralic tensioner rebuild, everything went great, new lifters new 204 cams new se adjustable pr, couldn't believe how easy everything went. So I get it all back together ready to hear her purr......but noooo. Press the start button she turns over great no unknown noises all sounds smooth but the bike won't start. Check everything and find my plugs aren't firing, I've done nothing to anything that should affect the firing. I've been through the flow charts in the manual, checked fuses, checked for codes, man I'm stumped! The only thing I notice about the plugs firing is every now and then when I'm turning it over, just as I let off the starter button I get one spark from the plug. Any thoughts?
The one spark when you let go of the button is normal, the ECM is turning off the coils because the motor isnt running and the coils discharge across the plugs.
That means the coils have power, and are talking to the ECM, but the ECM isnt firing them.
Did you check the crank angle sensor?
