Tour pack removal guys - in here please
Old 07-02-2012 | 05:04 PM
PhotoRider's Avatar
PhotoRider
Only thing is it gets much harder if you put on the ultra BOOM amp designed to mount on the trunk bottom... You need to use the street glide version which mounts in the fairing.
I am having a difficult time getting everything in the RG fairing - the GPS harness and the amp so I decided just to use the tour pack mount and always have the trunk...
Old 07-05-2012 | 03:57 PM
TheFaz's Avatar
TheFaz
1st Gear
Originally Posted by thefaz
thanks for all the info on the tour pak removal. It gave me the confidence to do my own the other night. Bought all the deutsch connectors, etc. But didn't use them as i just disconnected the wires with the stock plugs. I do have two questions, however:
1) i did not yet remove the horse shoe shaped bar/rack on which the pak mounts. Wasn't sure how it removes, or what has to be taken off to get to the bolts holding it on. Any help?
2) this probably has nothing to do with the removal, but my bike suddenly developed an intermittent of running a real high idle on start-up for a second or two. I'm talking revs to 4+k immediately on start up, then settles back down to "normal" range. Is there anything under the seat which i could have effected with the clump of bunched up wires now residing under there? Both battery terminals are tight and intact.
Thanks!
bump...
Old 09-09-2012 | 02:16 PM
doug5555's Avatar
doug5555
Stage II
can i get into any problems in taking off my tour pak on my 02 ultra,do all the wires unplug and will they store under seat,from reading it sound like all i have to buy is antenna relocation bracket,what about the amp under tour bag does it stay,i think its a amp?
Old 09-15-2012 | 05:56 PM
doug5555's Avatar
doug5555
Stage II
radio doesnt work no power when i turn it on i took tour pak off my 02 ultra do i have to hook speaker up somehow or i just rolled wires up and put them under seat
Old 11-06-2012 | 03:42 PM
Guzz's Avatar
Guzz
Originally Posted by michaelnmississippi
I purchased the detach kit and wiring kit. It was kinda expensive but the 2012 limited was also. That's why I could not bring myself to butchering the wiring harness . When my pack is removed I lay my harness and tour seat strap inside my left saddle bag . Install my street glide seat using seat bolt supplied in kit. Transfer my antennas from tour pack . All this takes less than 13 minutes . I love the ease of transformation
Do you have the part numbers you used for this? I have a 2012 Ultra and am looking to do the same.
Old 11-06-2012 | 03:48 PM
Glockmeister's Avatar
Glockmeister
Using the Harley kit is not the only way to do business, but it is easy.
Old 11-06-2012 | 05:49 PM
JohnnyC's Avatar
JohnnyC
If any bare wires exist:
Be certain all wiring is wrapped securely with electrical tape before stashing the rolled up bundle of left over wiring.
Also the speaker wires must be kept separate from each other being careful to never short any to ground.
sudbury2010glide
09-20-2012 06:54 AM
Mikes-10
04-29-2012 08:15 PM
dobber709
10-23-2007 01:34 AM
Bubba Zanetti
11-20-2006 02:56 PM
kevdog
06-30-2006 12:06 AM
Quick Reply: Tour pack removal guys - in here please
