ok guys, how do I fix this trim ring gap..
Do the pre-14 bikes have the black plastic trim piece behind the bezel that extends up over the light? I'm installing my visor trim ring and it seems to grip more securely with the factory ring behind it, but there isn't enough clearance between the factory visor and that black plastic piece for the visor to fit in without rubbing. I'm contemplating trimming the black piece down so it's just a ring behind the mounting surface to maintain clearance, which will give me the clearance behind the light bucket ring for the lip of my visor ring to grip.
Visor Trim Ring gap removal
Hi, There is finally a solution that work well and easy to install. it is the trim gap removal. I tried different method on the post, ad they either does not work..for me. or create different problem, like gap around the contour, or the trim ring turn on itself, or water entering the headlight assembly... and they were mostly hard to install or required drilling the headlight assembly.
With this ingeneous system, everybody can install them in minutes, No drilling, welding, cutting etc.. with full pictures guide. See attachment or see this site. www.hayteaser.com, and go to new product.
Hi Giuseppe, The site was not update on time for the new product, sorry about that. It is now on the site, as new product. www.hayteaser.com. This product will easily close the gap and will leave no gap around the headlight either, no drillng, cutting or welding. Enjoy
My solution last summer was to not use the trim ring over the stock ring. What I did was to run a strip of the thick rubberized weather stripping, probably the 1/2" wide x 1/4" thick around the space just behind the headlamp mounting plate. You get the idea. That offered enough fill and sealing to securely tighten the trim ring with no gaps anywhere. Looks and works great. No pic now because it's -20 here and the bike is in storage... Cmon spring.
