Catastphic Meltdown Ouch this will cost me
04-20-2012, 07:21 AM
That engine had much more than a tune issue going on.
04-20-2012, 07:27 AM
head and spark plug melted together? Good lord, what kind of fuel where you using? and only on the front cyl. I would think it would have done the rear one first.
04-20-2012, 08:16 AM
Sorry to hear, good luck with the new motor. It will run better.
04-20-2012, 08:33 AM
Must have been way lean for some reason
04-20-2012, 09:44 AM
Quote:
Originally Posted by
1931jamesw
The SERT has more ability than the Power Commander and better yet, it's already paid for. Why would you do away with it and go to a Power Commander?
That's debatable.
04-20-2012, 09:56 AM
Lean fuel mix and low oil maybe? And on the front instead of the rear? That's totally bazaar.
04-20-2012, 09:58 AM
DPete
Probably a partially clogged or failing injector.
04-20-2012, 10:02 AM
getting that hot, I might suspect more damage than just top end. rod bushings cooked to point of not repairable?
04-20-2012, 01:26 PM
harleycharlie1992
Good time for stroker crank!!
04-20-2012, 02:12 PM
mike_oh
seems the only logical answer to me!!! no replacement for displacement!!
