gear oil smell
04-19-2012, 09:56 AM
gear oil smell
Is it normal to smell a little gear oil occasionally when at idle, like at a stop sign or red light?
04-19-2012, 10:03 AM
Its more prevalent if the bike is running dino oil. You really dont smell it if your running synthetic.
04-19-2012, 10:05 AM
I should ask however, is it gear oil or really hot motor oil your smelling and do you see any signs of a leak?
04-19-2012, 10:19 AM
Location: Western Illinois, land of bad roads, and corrupt politicians
Are you sure it's coming from
your bike? I smell antifreeze when I stop sometimes
04-19-2012, 10:27 AM
I have had a similar smell myself. It has happened several different times even when there are no cars around. I did put Spectra in my Tranny when I changed my clutch cable. It's not bad and does not stay around long. And no leaks that I can find. No marks on the garage floor.
04-19-2012, 11:00 AM
Here's what's happening.......
You are smelling the gear lube after it heats up a little bit, and the smell is coming from the transmission vent tube.
Some lubes have an odor, and when they warm up, it gets worse.
04-19-2012, 11:09 AM
Redline is good stuff buy it does have a "sweet stank".
04-19-2012, 11:17 AM
That is quite possibly a stator burning up.
04-19-2012, 11:57 AM
Quote:
Originally Posted by
TUCCI
Thanks for all the replies. It's definately gear oil... there's no mistaking that smell. There are no leaks. I changed the gear oil about 750 miles ago. Put in Amsoil 75w-140.
04-19-2012, 11:58 AM
shooter5074
Thanks, shooter.
